buRRp's 1991 V2500 Suburban Build
buRRp
Supporting Member
Staff member
Supporting Member
Just a quick update...
Well a couple weeks ago I flushed the radiator and put some stop leak in it to try and stop a small leak. Well it ended up the radiator end tank is wore out so I will be having it redone this Friday. Also found out that the motor for the end gate window is bad and needs to be replace. The window is down and I can't get to the motor so I am still trying to figure that out. :confused: :frustration: Nothing major done lately as I have been very busy with work. Hoping to get time some weekend soon to head out to my buddy's to build the back bumper and do a few other little things.
dirtyoldman
Saugus,Ca.
Might have to replace the end gate.Check your local pick-a-part,might find one cheap.Bring a cordless drill battery with you and a couple of wires so you can jump the wires going to the gate to make sure the motor's still good.I've done similar with a cordless battery.....
dirtyoldman
Saugus,Ca.
Had a 87 Mustang where the door locks took a shit so went to our pick-a-part,with a battery and tried a few Mustangs until I found one with a good door lock motor....
Sure would be nice if they'd build things so it could be fixed fairly easy
