94 Chevy Beretta Z26
Should be able to remove the rear seat to get to the pump. Most cars will have an access panel to the pump/tank under the rear seat.
davbell22602
Stihl Chainsaw Man
Bunker Hill, WV
The Beretta's dont have a access panel under the rear seat to the fuel pump. Fuel tank has to be dropped.
I've never seen a GM car with an access panel under the rear seat. I've seen a LOT of other manufacturers do that though. If GM does do that, it must be something they started after 2000-2005 or so. I remember helping my brother change the fuel pump on a mid 90's Pontiac Bonneville. It was fuckin hell. :lol:
Best test for the fuel pump is to poke a hole in the tank and then light it.
davbell22602
Stihl Chainsaw Man
Bunker Hill, WV
Anyway to bypass the fuel pressure switch to see if the car will without it? If not how do you test it? There's nothing in the Haynes about a fuel pressure switch. Just shows it in the wiring diagram.
Poke a hole in the fuel tank and light it.
