hotrodpc
- Joined
- Jun 28, 2009
- Posts
- 1,012
- Reaction score
- 1
Not even sure anyone is interested in this ugly truck, or a truck this old here. Seems to be site for nice newer trucks. Not sure its being posted in the right category either, but that is what Mods are for right? Moving threads or deleting them if they don't fit. This is from my 84 C2500 Truck that I got for $100 with a rebuilt 454 and blown Turbo 400. I had been having to fill that tiny rear brake resevoir about every other day, so I knew I had a leak of some kind. I was outside at work and noticed a puddle inside the right rear tire. Thought, damn if thats my leak, its a bad one. Sure enough, brake fluid dripping out of the drum. That day when I got home, I called for parts availabilty and prices immediatly. Wheel cylinder rebuild kit was $6, which what I usually do. When I noticed the NEW Wheel Cylinder with a Limited Lifetime warranty for $13 guess what I decided to do??? No need to worry if its pitted with rust, no need to hone it, no need to replace the pistons if needed, and LLT warranty, so sure, I bought new wheel cylinders and save a little labor too. Had a bit of a problem. It has been years since I worked on a Full Float rear axle. I was looking for the tangs to bend over to get the hub not off. There wasn't one. Posted on another site asking how to get it off, no response, and I didn't have time to wait. Maybe I should have posted here. I know there is at least one 14 bolt Full Float guru here. Finally I noticed the keeper retaining ring, popped it off with ease using a standard screwdriver, backed the nut off the keyway, and the keyway slides out easily. What I found was extremely saturated shoes as expected, but the shoes were good and lots of use left. Maybe only 25% wear. Drums did not even have a glaze on them and were nice and smooth, looking like a recent turn job. Being that I did not replace the shoes or turn the drums, I just bought 2 wheel cylinders, 2 Timken wheel seals and 2 cans of CRC brake clean to clean off the shoes and saturation off the backing plate. Total cost of $47 including tax. Here is what the bad leaking side looked like.
Sometimes I do these forum things for notes to myself and other people benefit too. Seems you guys on this site all have newer vehicles though, and most of the stuff I have like this is for the older models. Someday I get energectic, I may post some pics of a Turbo400 I rebuilt for this truck. It was a nasty job since this trans came apart towing a loaded trailer on a move across 2 states and it was burnt badly. This was how I ended up with the truck for $100.
