bubbatrucklover
Heavy Metal Red Neck
The grommet I'm talking about is under the door sill trim on the rear passenger side. Not sure if you guys have one but it makes life a heck of a lot easier running power wires back there. As far as protecting it, when I did my first install I didn't put anything over it and it was fine. To be safe this time I put 1/2" wire loom over both of them. That will be enough to keep dirt and debris out. As long as the wire isn't cut I don't see a problem. If you want to be extra careful they make this stuff called Tech Flex.
Yeah they don't leave us much room at all. Packaging science at it's finest.
Take some before and after pics of the dog hair--you'll be amazed at the difference. What I did was use a strong little hand vac to get up a lot of it, then used the glove to ball the rest of it up, then used the vacuum again to get the ball of hair up.
I started to look underneath for the grommet(if the grommet excists on mine) but it started to rain.
I'm going to look at the firewall one and underneath again tomorrow. I'm way off on doing it but planning ahead is best.
I'm actually excited about the glove thing. I'll be wondering around the house with one now too.
