WTH! Radiator Leaking Now.
JB weld makes a repair "putty" for use on radiators and gas tanks. I used it before on an old car I had, planning on it just being a temporary fix until I had enough money to get a new radiator. However, it held up just fine and was like that when I sold the car about a year later. But it wasn't on the actual tank, the joint where the fill neck met the tank was leaking so I covered that whole area around the neck and it worked great. Maybe you can try that as a temporary solution.:dunno:
Hickspanic
D-ville
A step-by-step on how to fix it
1. open hood
2. remove radiator cap
3. drive truck away
4. place new truck under old cap
5. install cap
6. enjoy fix
txab
Don't get stuck on stupid!
So will you have a radiator shop swap it out for you? After all something might break and you'd be stuck
