svensk
TMC's official Zombie Slayer
.607" is a pretty tall lift value ... you going to do anything to the heads down the road? Otherwise I'm not sure why they are going for that much lift.
His 243 heads are the same as I have. They flow more than the 5.3 can push N/A. His lift is pushing it, but his duration, displacement and compression are all pretty mild yet.
Yeah, my point is that a .600"+ lift is a bit excessive for that profile and head. If it's not going to do much for the setup then there's no use in the extra lift adding exponential amounts of seat pressure and spring bind.
It's hard to say that it won't do anything though, if you can accelerate the valve quickly then it will pull negative pressure at the port. Just have to have enough spring bind to soak up the inertia and keep it from bouncing at higher RPM.
Another way is to run excessive lift so that you can slow the valve down on the way back and hold it open a tad longer on the overrun for scavenging. Since lower RPM is where you get the most charge dilution, it kinda looks like that's the motivation here. Until you get the valve past 0.050" you're essentially choked at the port.
There are lots of stealth cams that run high lift .600+ for scavenging.
