Coolant and hoses change
Original? How did the hoses look? I still have them on mine. :lol:
No, replaced originals 6 years ago or so./ While they do last longer using DEXCOOL they still break down. My upper hose had some serious cracking internally in a spot
Well, I switched over to the green coolant about 10 years ago. I guess it would be a good idea to change out all of my hoses as well. I take it Rock Auto is the place to go?
txab
Don't get stuck on stupid!
That's where I got this last set, I always use Gates. I always compare to local. Usually RA has the better price if all the hoses ship from the same warehouse.
Todays rubber compounds are light years better than what we had 30 years ago. If you're running originals after 12 years or so, I'd think I'd be a changing them. You got your moneys worth. :)
Do yuo still have the quick disconnects at the heater core? If so I'd replace those. One of mine was beginning to fail and crack. I re-used the OE ones at the first hose change. I just used the Dorman part to replace. You'll need the little disconnect tool to get them loose. You can also just put the hose directly to the heater core and clamp them.
Next thing fro me to tackle is a P0300. Only get it at highway speeds under hard acceleration at speeds over 75 or coasting throttle closed down a long hill etc....
Your '02, 5.3 should use the same
Part #'s
18914
22437
18126
22554
18623
800409 Dorman 2 required
I still use spring clamps at the radiator connections. Screw type seem to start weeping after a while due to the constant expansion and contraction of the plastic radiator tanks. Screw type everywhere else
There is one more hose from rad to reservoir, but I just buy bulk hose for it. I didn't replace it this time
Part #'s
18914
22437
18126
22554
18623
What is the disconnect tool I need for the heater core? I prices these all out and it runs to $85 from RA.
Thanks for the part numbers. I ran them against my model in RA and they match as I thought they would.
Now to get some fresh AMSOIL coolant. :)
