Want to install an OE style fan in my 96 F-250
Lonesome7.3
By whatever means necessary …
Columbus, GA
The Lincoln Mark VIII fan is what I was looking for when I found the Trooper car. That is the mod the racers use that I use to know. The two Lincoln Mark VIII fans I have are the same size and shape as the Trooper fan. o they will not fit either. Damn...
Look for a Lincoln Mark VIII fan or a Tbird with a V8 fan those pull enough air. You can also try to find the dual fan set up from a 3.8 Windstar.
I heard this on other forums too. They also say early 90's Taurus fans move a shitload of air. Measure your available space (width and height) and I can measure my 06 Tahoe fans. I have the dual fan setup with shroud that came on 05-06 Tahoes, Suburbans, and Silverados.
They move a TON of air when both fans are on high.
Lonesome7.3
Columbus, GA
The windstar is a good idea as well. I just happen to know where a few are sitting.
