Unusual problem
bigredstx
If they don't scrub, they're not big enough
CEL finally stayed on and it read P0506 or something which was "idle control sensor".... $400 and a new throttle body to fix it :(
NWSCREW
Chrome won't get you home!
Scappoose, Oregon
Shop manual states:
MIL ON—P0506 AND/OR P0505—HESITATION/LOSS TSB 08-18-2
OF RPM/DIFFICULTY STARTING/LOW IDLE RPM
FORD: LINCOLN:
2005-2007 Crown Victoria 2005-2007 Town Car
2006 Mustang, Mustang 2006 Mark LT
2004-2006 F-150, F-150 MERCURY:
2005-2006 E-350, E-450, F-Super Duty
2005-2007 Grand Marquis
2006 F-53 Motorhome Chassis
2006-2007 Mountaineer, Mountaineer
2006-2007 Explorer Sport Trac, Explorer
This article supersedes TSB(s) 08-5-13, 07-23-12 SERVICE PROCEDURE
and 06-25-8 to update the Service Procedure.
1. Reprogram the powertrain control module
ISSUE (PCM) to the latest calibration using IDS
Some 2004-2006 4.6L and 5.4L F-150 (excluding release 53.9 and higher or 54.1 and higher.
F-150 Heritage), 2006 5.4L Mark LT, 2005-2006 This new calibration is not included in the VCM
6.8L E-350 / E-450, 2005-2006 6.8L F-Super Duty 2008.1 DVD. Calibration files may also be
(F-250 to F-550), 2006 6.8L F-53 Motorhome obtained at www.motorcraft.com. The calibration
Chassis, 2006-2007 4.0L Explorer 4 dr, 2007 4.0L contains a sludge compensation strategy for the
Explorer Sport Trac, 2006-2007 4.0L Mountaineer, throttle body.
2006 4.0L Mustang, 2006 - 2007 4.6L 3V Explorer / 2. Turn the key off to re-initialize the PCM. This
Explorer Sport Trac / Mountaineer, 2006 4.6L 3V will allow the sludge compensation strategy to
Mustang, and 2005-2007 Crown Vic / Grand learn.
Marquis / Towncar vehicles may exhibit one or
more of the following symptoms: drive-away 3. With the vehicle in park or neutral and A/C off,
hesitation, loss of RPM on deceleration, difficulty start vehicle and allow engine to reach normal
starting, and/or idle RPM less than desired. operating temperature(greater than 170 °F (77
Malfunction indicator lamp (MIL) may be illuminated °C) coolant temperature). Run an additional 5
with diagnostic trouble codes (DTCs) P0506 and/or minutes to allow sufficient learning time.
P0505. These conditions may appear after battery
disconnect, dead battery condition, or keep alive 4. While the engine is running, using IDS
memory (KAM) reset. The symptoms may be due to datalogger or equivalent, check the PID value
engine deposits in the throttle leading to airflow less of ETC_TRIM.
than desired. a. If ETC_TRIM value is 3.5 degrees, and/or
ACTION DTC P115E is present, then replace the
electronic throttle body (ETB), following
Follow the Service Procedure steps to correct the
Workshop Manual (WSM), Section 303-04B.
condition.
b. If ETC_TRIM value is less than 3.5 degrees
and DTC P115E is not present, but
driveability concerns persist, the ETB is not
the likely cause of the concern and
replacement is not necessary. Continue with
normal PC/ED diagnostics.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a
Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation
determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin
(TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is
available through Ford Motor Company’s on-line technical resources.
Copyright ã 2008 Ford Motor Company Online Publication Date August 21, 2008 PAGE 1
TSB 08-18-2 (Continued)
NOTE WARRANTY STATUS: Eligible Under Provisions Of
VEHICLES EQUIPPED WITH A PCM AND TCM New Vehicle Limited
REQUIRE COORDINATED REPROGRAMMING. Warranty Coverage And
THIS COORDINATED REPROGRAMMING Emissions Warranty
PROCEDURE MUST BE FOLLOWED EXACTLY Coverage
AS OUTLINED BY THE IDS. FAILURE TO IMPORTANT: Warranty
FOLLOW THE KEY CYCLE PROCEDURE coverage limits/policies are
WITHOUT WAITING FOR THE IDS PROMPTS, not altered by a TSB.
WILL CAUSE THE COORDINATED Warranty coverage limits
REPROGRAMMING TO FAIL. THE PCM WILL BE are determined by the
UPDATED BUT THE TCM WILL NOT BE identified causal part.
UPDATED AND NEW FILES WILL NOT BE OPERATION DESCRIPTION TIME
INSTALLED. IT IS CRITICAL TO FOLLOW THE 081802A 2004-2006 F-150 0.4 Hr.
IDS PROMPTS. SOME VEHICLES MAY REQUIRE 4.6L/5.4L, 2006 Mark LT,
SEVERAL DAYS OF DRIVING FOR THE Econoline 350/450 6.8L,
TRANSMISSION TO FULLY ADAPT. 2005-2006 F-Super Duty
REPROGRAMMING CONCERNS/ERRORS MAY 6.8L, 2006-2007
BE CAUSED BY THE DATA LINK CONNECTOR Explorer/Mountaineer 4.0L,
(DLC) OR VEHICLE COMMUNICATION MODULE 2007 Explorer Sport Trac
(VCM) BECOMING DISCONNECTED, LOW 4.0L, 2006 Mustang 4.0L,
BATTERIES ON THE INTEGRATED DIAGNOSTIC 2005-2007 Crown Victoria,
SYSTEM (IDS) OR THE IDS GOING INTO ANY Town Car, Grand Marquis:
TYPE OF SLEEP MODE, OR LOW VEHICLE Check For DTCs And
BATTERY VOLTAGE. IF THERE WAS AN Reprogram The PCM,
INTERRUPTION DURING REPROGRAMMING, Includes Time To Monitor
MAKE SURE THE ORIGINAL IDS SESSION THAT ETC_Trim Value,
WAS CREATED FOR THE VEHICLE IS NOT Authorization Decal NOT
DELETED. IF THE ORIGINAL VEHICLE SESSION Necessary. (Do Not Use
IS NOT USED OR DELETED BEFORE THE With 9926A, 12650D)
MODULES ARE COMPLETELY REPROGRAMMED, 081802A 2006-2007 1.0 Hr.
FURTHER REPROGRAMMING ERRORS CAN Explorer/Mountaineer 4.6L,
OCCUR. THE MODULE RECOVERY PROCEDURE 2007 Explorer Sport Trac
IS NO LONGER AVAILABLE AND IT IS CRITICAL 4.6L: Check For DTCs And
THAT MODULE SWAPPING IS NOT PERFORMED Reprogram The PCM And
FROM VEHICLE TO VEHICLE. TO REGAIN TCM, Includes Time To
COMMUNICATION WITH A MODULE THAT HAS Monitor ETC_Trim Value,
BEEN ERASED DURING REPROGRAMMING, Authorization Decal NOT
RESUME THE ORIGINAL SESSION ONCE THE Necessary. (Do Not Use
IDS IS RE-BOOTED. With 9926A, 12650D)
081802B 2004-2006 F-150 5.4L, 0.9 Hr.
PART NUMBER PART NAME 2006 Mark LT: Check For
9W7Z-9E926-B Throttle Body - 4.0L, 4.6L 2V, DTCs And Reprogram The
8L3Z-9E926-B Throttle Body - 5.4L PCM, Includes Time To
9R3Z-9E926-B Throttle Body - 4.6L 3V Mustang Built Monitor ETC_Trim Value,
After 12/7/2005 Replace Throttle Body,
6L2Z-9E926-C Throttle Body - 4.6 3V Explorer, Sport Authorization Decal Not Trac, Mountaineer
9C3Z-9E926-B Throttle Body - 6.8L Necessary. (Do Not Use
With 9926A, 12650D)
PAGE 2
081802B 2004-2006 F-150 4.6L: 0.8 Hr. 081802B 2006-2007 Explorer, 0.8 Hr.
Check For DTCs And Mountaineer 2007 Explorer
Reprogram The PCM, Sport Trac 4.0L: Check
Includes Time To Monitor For DTCs And Reprogram
ETC_Trim Value, Replace The PCM, Includes Time
Throttle Body, To Monitor ETC_Trim
Authorization Decal Not Value, Replace Throttle
Necessary. (Do Not Use Body, Authorization Decal
With 9926A, 12650D) Not Necessary. (Do Not
081802B 2005-2006 Econoline 6.8L: 1.1 Hrs. Use With 9926A, 12650D)
Check For DTCs And 081802B 2005-2007 Crown Victoria, 0.8 Hr.
Reprogram The PCM, Town Car, Grand Marquis:
Includes Time To Monitor Check For DTCs And
ETC_Trim Value, Replace Reprogram The PCM,
Throttle Body, Includes Time To Monitor
Authorization Decal Not ETC_Trim Value, Replace
Necessary. (Do Not Use Throttle Body,
With 9926A, 12650D) Authorization Decal Not
081802B 2005-2006 F-Super Duty 0.9 Hr. Necessary. (Do Not Use
6.8L: Check For DTCs And With 9926A, 12650D)
Reprogram The PCM, 081802B 2006 Mustang 4.0L/4.6L: 0.8 Hr.
081802B 2006-2007 Explorer, 1.4 Hrs. Necessary. (Do Not Use
Mountaineer 2007 Explorer With 9926A, 12650D)
Sport Trac 4.6L: Check DEALER CODING
For DTCs And Reprogram CONDITION
The PCM And TCM, BASIC PART NO. CODE
Includes Time To Monitor RECALEM 04
Throttle Body,
With 9926A, 12650D)
98k1500
Green Bay, Wisconsin
My truck has been doing crazy stuff lately. Im really not sure how to describe it but when i go to slow down and come to a stop it was shut off. Its also idles erratically sometimes. I just bought a fuel filter and im going to change it but do you guys have any other ideas? its a 2006 4.6 with 97k miles :ohnoes:
do you have a IAC(idle air control)
