Truck makes grinding noise when on left curves
hemiv8dodgeram1500
Pickup driver by choice, Ram driver by the grace o
N/A
yes a 4x4 and the dealer looked at everything and said it was fine but it is driving me nuts.
I imagine it is driving you nuts. Nothing worse than a noise you can't find. Good luck with it, maybe somebody will have an idea.
dietz4ibanez
Willow Spring, NC
Does it seem as if your tires are rubbing? One would think thats impossible with stock tires. :dunno:
Could there possibly be some kind of foreign matter stuck in there somewhere? :dunno:
Can you jack up the truck and try turning the tire by hand? Try rotating while turning lock to lock. You mey need another hand to assist in turning the steering wheel.
lilfroger
HP is how fast u hit the wall ... TQ is how far u
WA
Is there any vibration w/ the noise?
Vibrations in the Dodge front ends are known to be caused by bad hub bearings, steering linkage, ball joints, or u-joints.
norcalmud
suck squeaze bang blow thats how a motor goes
nevada city
the u joint would cause the wheel to jerk back and forth because it would lock up
