Sub Impedence
Z71 Kris
Independence...
N. East Ohio
you could use this AudioQue..http://www.audioque.com/AQ750-Amplifier_p_46.html, I just recomended it to Jon(boilerup) for his accord, it looks like about 400 rms at about 3ohm....or you could do this rockford for a little bit morehttp://www.crutchfield.com/p_575R5001/Rockford-Fosgate-Prime-R500-1.html?tp=35834&nvpair=FFBrand|Rockford+Fosgate
Why do you want that jl; anyways? Hard to match amp wise, and can get comparable things for way less money?
How do you figure out what it outputs at 3Ohms?
As far as why JL. I have friends with all different kinds of setups. The one that impresses me the most as being most versatile is the one that has a JL. It hits all the low notes and is really good for rocking bass riffs. I listen to everything so I want something that hits hard and fast, but that I'm not afraid to bump every once in a while.
a lot of that is box and amp...you kinda guess-ta-mate 3 ohm, since jl is one of the only 3ohm brands nobody really marks what power is at 3ohm, you take 4ohm and 2 ohm what is in the middle is your 3ohm power, but again, I know this is personal preference and all, but there are dozens of subs I would buy before a jl, especially for their price...
99sierraman
[don'tcha know]
Minnesnoowta
What would you suggest for a good 8" or 10"? I'm still kind of evaluating options so a couple of suggestions from both would be awesome. I just started with JL because I was so impressed by the 10" my friend had.
99sierraman
[don'tcha know]
Minnesnoowta
Yes. I'm planning on making a custom box so that I can put it on the hump. I use both sides under the bench for storage. If I have to do shallow mount I will. Other wise I am pretty sure I can make an 8" fit. Don't worry about "being a dick" haha, I enjoy people's opinions. Have have a lot of knowledge in the area, but by no means do I consider myself an expert.
Boilerup15
Hate Milk! Got Beer?
Markle, Indiana
That AQ amp is bad ass! I just went with 2 10" Rockford P2's. I don't have them turned up all the way yet since they are new, but they already hit pretty good with that AQ amp. I had the Kicker CVT 12" shallow mount in my truck, I liked it. I actually still have it if you would be interested in buying, but shipping would probably be a bitch.
Z71 Kris
Independence...
N. East Ohio
http://subthump.com/Chevrolet-GMC-Sub-Boxes/Silverado-Sierra-Extended-Cab/99-06-GM-Extended-Cab-Dual-10-Downfire-With-Amp-Space.html'
something like this for your box..
http://www.crutchfield.com/s_575P2D410/Rockford-Fosgate-P2D410.html?tp=111&nvpair=FFBrand|Rockford+Fosgate&nvpair=AG_Box_Type|FFSealed&nvpair=FFSize|%5brank7%5d10%22
and either of those amp I posted earlier...the AQ or the rockford..
edit* disregard, I did not see that, I would need to know you mounting depth to give good recommendation...
Z71 Kris
Independence...
N. East Ohio
sooo..enjoying it so far?
