Possible bent steering column.
slims
gonzales LA.
Warranty should cover it.
slims
gonzales LA.
Think it's is bent? Anyone ever have this happen?
slims
gonzales LA.
After I heard the noise, I lifted the carpet to see if it was something under there causing the noise.. Nothing :dunno:
Maybe?
Ask the guy standing there in your shoes who can actually see the shaft, and see what he thinks. If the shaft isn't bent, you might ask him to move the tubing back and out of the way and see if that helps.
You might have to ask him a few times to get him to understand, but I bet he'll help. :D2
slims
gonzales LA.
That sounds like a terrible idea..
mr_bots
Fort Kickass
The shaft just sees twist, t'd be pretty hard to bend it unless you hit it with something. Maybe a bolt on the rack is loose and pushed it over a little? I'd imagine you'd **** up a tie rod doing that way before you'd do anything to the column.
slims
gonzales LA.
I'm dropping it off at the dealer tomorrow.. I just got back from sitting in the sun for 5 days. And I made sure I had a warranty for this exact situation.
