Early in May, I finally found the S10 I had been looking for (after 4 months of searching).
1998 Chevy S10 ZR2
137,735 miles (when bought)
extended cab (no 3rd door; 2 jump seats in back)
5 speed (what I had been searching for!!!)
push button 4x4 (not sure if manual was even available)
power windows & locks
A/C (that works too!)
cassette player
The previous owner replaced the entire cooling system (radiator, water pump, thermostat, heater core, hoses). The tires that are on it are in great shape and should last me 3-4 winters (hopefully more). It has bars in the bed for a 5th wheel hitch (will be coming out), electronic brake controller (will be coming out; might add my own later, I have a box for the Silvy so I'd only need the wiring harness), cold air intake (looks like the cheapo one off eBay that has the filter open to the engine bay heat). In the interior, the dash has obviously been removed for the heater core and I believe the previous owner cracked/chipped it in the process so that will be getting replaced, both seat reclining handles are broken (go figure; weak aluminum was used), and the carpet is stained in the back (will be shampoo-ing). The driver's door has been replaced with one that had plastic cladding (must be from a Blazer with the Trailblazer package or a Jimmy) so there are holes and tape (I'd weld them up or bondo them).
Plans
Black Bear Performance tune
Anzo 111016 projector headlights - have them
APC 403027CLD parking lights - have them
Hella 500FF driving lights (mounted on bumper - have them
HID's (highs & lows) - had them already
new OEM looking grill (possibly PTM'd minus the chrome bar)
mud flaps and floor mats (to protect it from salt/dirt in the winter)
new dash - have it
factory CD player - have it
eventually
exhaust (both Magnaflow bolt-ons)
CAI (Volant or the seemingly very functional one that someone online came up with themselves on another S10 forum)
It runs and drives great. No noises, shakes, or surprises. The tires are in great shape too!
A couple of problems came up on the way home:
1) Wipers don't work. - Washer fluid does and fuse is fine, but they don't move. I'm hoping that the circuit board in the wiper motor is shot since its only a $30 part. - I tried them latter after getting home and they worked.
2) Driver's window switch is wired backwards. - Its physically in the correct position, but up=down and down=up. I'm hoping the motor is plugged in backwards.
3) Tachometer needle is jittery. - it jumps RPMs, but seems accurate. - Is there something dirty/corroded?
Anyways, apparently he put it on eBay for $3500.
As far as body work goes, I hope to at least repaint the scuffs, dents, and small rust spots along with the tailgate. If I have time this summer, I'd like to try to get the dents popped out as best as possible. I need to shampoo the carpet and I have an air freshener in it (guy was a smoker, but he ran a ionizer in it for 8hrs; doesn't smell all that bad to me). Oh, and the 5th wheel hitch bars in the bed are coming out too along with the electronic brake controller.
Overall, I'm very happy. I gained 4wd and 40k miles less. My blue '97 S10 will hopefully be on CraigsList by this weekend.
1998 Chevy S10 ZR2
cassette player
Plans
new dash - have it
eventually
PTM grill. Paint the black and chrome of grill but leave the bumper black to match the flares. Friend of mine did that to his ZR2 of the same color and it looked really good. Otherwise the mods list looks good.
