I use def. About 6 gallons every 1000 miles. Not all trucks use DEF. Cat used a system that used diesel fuel to send a flame down through the exhaust like a furnace. It sucked. I don't miss working on them.
Cat's are a powerhouse though
Cat's are a powerhouse though![]()
I do miss driving the custom trucks that came in. My favorite was a Day cab Pete that I did an In-Frame overhaul on. It had a 625 C16 in it with 10" straight pipe stacks. That was the best road test I ever took a truck on after an overhaul. That bitch could PULL!
It's availiable at pretty much every fuel station here...
I could be wrong on this, but I believe that its not readily available in Brazil yet because the emissions regulations aren't at the same level as they are in the US/Canada. It will catch up down there soon enough though.
Here it's still not available at fuel stations
As far as I know, this setup is used to "regenerate" the DPF.
American emission standards are equivalent to the Euro-6. Back here Euro-3 was enforced until January, but SCR started in Europe with the Euro-4, and here Euro-5 is now enforced but it's still not so easy to find the DEF nationwide. Due to the 2008/2009 recession, Euro-4 was jumped over.
The SCR system still does regeneration... Or at least has the capability for regeneration if needed. Otherwise it wouldn't even NEED a DPF
SCR isn't mandatory here... It's just working better than the DPF and regen setup.
International is fighting the gov't to prevent SCR from being mandatory... They're going to follow CAT in their failed attempted at doing the DPF regen thing to control emissions...
SCR system is not supposed to clog like the DPF...
Neither here the SCR is mandatory. Some engines are already certified just with EGR and twin-turbo, altough in some smaller engines the SCR leads to a lower decrease on power without the higher cost of a twin-turbo. As far as the DPF regen goes, it's not so unusual.
