vansdonk
That's not buffing out
I like the black one.
Unless you're going to use it off-road I would keep it the way it is. It looks a lot cleaner now. If you're using it off-road and need the improved approach angle and protection then 1
Sent from my Droid using Tapatalk
this is going to cost me less then a 100 bucks to makeKeep it and blow the money on a supercharger instead!
now you know why i said what i did bro^^^^^ Just fWONking with you George, 1 would look bad ass I say DO IT!
i was thinking about doing mid travel suspension, but leo aka ogterror thinks i should do a SAS swap so for the the suspension stays as isUnless you're going with a long-travel front suspension, skip the prerunner deal. That look without the performance is just kinda... lame.
Keep it as is and fab up a cool looking skid plate to tie it together and up the looks.
Well it depends on what you want to do with the truck. If you want to go blasting through the desert, long or mid-travel would be the way to go, but if you want to convert to 4wd and do more crawling and trail riding, the solid axle would be the way to go.
