Nice write up thanks for posting.
Is there a way to reset the needle if some one pulled it off once without marking it?
Sent from my iPhone 4s
The only way I know of is to manually calibrate the needles with the truck running. You will need a scan tool that will tell you the RPM's, temp, etc. The speedo will be tricky since you will need the truck moving. Do it with a GPS to tell you the speed on a straight empty highway with the cruise control on. And for the fuel gauge, fill it up and move the needle to full.
