Head Unit Help!
Hickspanic
D-ville
RADIO C1 - WHITE 22 WAY CAV CIRCUIT FUNCTION
1 - -
2 X12 18RD/WT FUSED IGNITION SWITCH OUTPUT (RUN-ACC)
3 E2 18OR/BR PANEL LAMPS DRIVER
4 - -
5 - -
6 - -
7 X54 18VT RIGHT FRONT DOOR SPEAKER (+)
8 X56 18DB/RD RIGHT FRONT DOOR SPEAKER (-)
9 X55 18BR/RD LEFT FRONT DOOR SPEAKER (-)
10 X53 18DG LEFT FRONT DOOR SPEAKER (+)
11 Z1 18BK GROUND
12 M1 20PK FUSED B(+)
13 X60 18DG/RD RADIO 12V OUTPUT
14 D25 20VT/YL PCI BUS
15 - -
16 - -
17 - -
18 X51 18BR/YL LEFT REAR SPEAKER (+)
19 X57 18BR/LB LEFT REAR SPEAKER (-)
20 X58 18DB/OR RIGHT REAR SPEAKER (-)
21 X52 18DB/WT RIGHT REAR SPEAKER (+)
22 - -
RADIO C2 - BLACK 10 WAY CAV CIRCUIT FUNCTION
1 X40 24GY/WT AUDIO OUT RIGHT
2 Z4 22BK/OR GROUND
3 C235 WT/LB CD GROUND SHIELD
4 D25 22VT/YL PCI BUS
5 X112 22RD IGNITION SWITCH OUTPUT (RUN-ACC)
6 X41 22DG/WT AUDIO OUT LEFT
7 Z140 22BK/TN GROUND
8 - -
9 E14 22OR/TN PANEL LAMPS DIMMER SIGNAL
10 X160 22GY/YL B(+)
Hickspanic
D-ville
I can also get you the cluster wiring diagrams too, if you want. :thumbs:
Boilerup15
Hate Milk! Got Beer?
Markle, Indiana
did you wire it straight or did you use an install kit?
I used a scoche install kit. The thing that threw me a little was it had 2 ground wires and 2 power wires. I hooked them both up by hooking them together then to the other corisponding wire. Just seemed funny to me that there were 2 of each.
Hickspanic
D-ville
did the cluster work at all with the radio hooked up? Like just in acc, or not at all?
Boilerup15
Markle, Indiana
Nope, it wouldn't work at all until I unplugged the radio. The radio worked like nothing was wrong. She also said her air conditioning wasn't cold anymore either, but I unplugged the radio and it started getting colder.
