Thats interesting, If its warm next weekend I may pull the back seat out and se what can be done.
Id like to try completly plugging the vents and see if there is a difference then diagnose from there.
Moved my bed to 1" space from bed to cab on both sides. Left side was 1" and passenger side was 1 and 1/4" . Move bed to 1". No change in noise.
Will put some dynamat over the passenger vent tomorrow. I'll post.
Hey Stumpuller 6.2, I have the same truck and color, but have a 5.3 and z71 4x4. I'm looking to swap out my door handles and mirrors from black to silver and change out the front grille to a Denali, and maybe look for some stock 20" rims. Could not get 20"s on a z71 from the factory.
I removed the passenger seat today and placed some "ghetto dynamat" over the vent. I cut a 18" piece by 6" wide piece and started about 2 inches above the vent and went down to about 2 inches from the bottom of the rear of the cab. Make sure you leave about a golf ball size opening at the bottom for the truck to breathe. So my passenger vent will still work. I also dynamatted other opening including the passenger corner and also above and below the seat belt mechanism.
as for my "Ghetto dynamat" I used a product called "easy roof" from "home depot" $16.00 for a roll 6" by 25 feet. It is used instead of dynamat because it is cheaper and has one side with foil on it. Do not use the "peel and stick" from Lowes because it smells like asphalt too much.
Drove it all day and NOOOOOOOO noise.
Hope this helps.
Damn sounds like some good ideas, when you get that done post up some pics, might make me get some ideas too!
Hope this helps.
That is awsome news, I knew it had to be the vents, so your fix does allow for some air movement? Do you possibly have pictures???![]()
i might try this fix
GM`s latest TSB. Supposed to be better then before.
10-08-58-001E as of march 8 2011.
