Shit, I misread what he was asking. I thought he said he didn't have the option to move them.
It's alright, I'm still half asleep.
Rear discs on that little Blazer would probably work great. In spite of what a lot of folks say, discs are not automatically better on larger vehicles. When the GMT900s came out, Truck trend listed them as stopping over 30 feet shorter than the GMT800s they had tested. I know that isn't exactly a head to head test, but it does show that the drums are working.
Front brakes do most of the stopping anyway...
+1...depending on the applications of the user..disc or drum doesnt matter as long as the vehicle gets stopped...although disc brakes are a little easier to change,,,i still like the old drum brakes myself..speaking of which i need to change mine..I agree Dan. As long as either system is designed correctly, it should work fine. Discs do look better!
I installed disc brakes on my gmt400. Both it and the sierra I had both came with disc brakes. I don't think were available until you get into the heavy Chevy's
How hard was the swap? Just pull the parts from a GMT 800?
Resurrecting this thread, as I am after the same information.
My diff took a crap on me, and I've always wanted rear discs. I have available to me a complete GMT800 10.5rg 14bff rear axle with all recently replaced brake components with gears that match mine for less than what I paid for the Mag Hy-Tec diff cover
If it's merely moving spring pads and shock mounts, that's entirely do-able.
I have read somewhere that it is little more than 1" wider, but that would actually be good for me because the GMT800 Alcoa Alum rims I use, create a 2" offset between front/rear width of where tires hit the ground. There are obviously spacers available to compensate for this, but I never saw the need to buy expensive spacers that resulted in added stress to all the rear axle components for claimed "greater stability" at hwy speeds...but having the axle itself being that much closer to the width of the front width, would only be beneficial.
Can anyone who's done this confirm what's involved and report their experience(s) in way truck drives after complete?
Thanks!
