at this time installl your axle, grunt a swear here> _________ . put a bit of anti sieze on the splines of the axle for future ease. install the 6 inner flange bolts with blue loctite, and torque to 58 ft/lbs, install washer and nut on the outer end of the shaft, tourque it to 165 ft/lbs. at this time you can re install the lower shock bolt and torque it to 66 ft/lbs.
i opted to run the buffer on my rotrs for now (just rotate rotor by hand and buff away)
you can now re-install your caliper (lube your pins first), torque the two retaining bolts to 15 ft/lbs. route your brake hose and install the retaining bolt into the knuckle (including the abs wire mount under it)
also route your abs wire and pinch the clamps back to hold it in place.
so the only thing left to do is re-install your outer tie rod, it should be torqued to 46 ft/lbs, and its not a bad idea to throw some loctite on there. you may have to use a large prybar to put force againt the bottom of the tie rod to keep the stud from spinning. you can re-install your inner fender liner too.
That about wraps it up i will post all the torque specs seperatly for ease of copy-pasting info.
Its a good idea now to make sure everything is tight and secure, grease the rest of the truck while the grease guns out, install your wheels and torque the to 125 ft/lbs.
