First mod
X pipes flow a little better.
H pipe = more power in lower rpms and deeper exhaust tone.
X pipe = more power in higher rpms and a little higher pitch sound.
I prefer the x pipes on the 4.9's. I had one on a 91 4.9 Mustang I had and it sounded bad ass!
That said, yes an H pipe will work also.
It's a truck, low RPM power FTW! :jester:
crmzendrgone
I may be fat but your ugly and I can loose weight
Arizona
How does an X pipe flow better than and h I kinda understand but not seeing the science behind it:confused:
All the H or X pipe actually does is equalize pressure between the sides. Technically, they are just crossover pipes. Both actually accomplish exactly the same thing. The X pipe looks better.
crmzendrgone
Arizona
Ah that is what i was thinking couldn't put it together in my head that well.
Like Darth said, sound can be affected. Not sure about the performance differences but it is certainly possible on different vehicles.
You won't know how it sounds until it's done.
Even if you take two of the same vehicle, it can end up with a different sound :dunno:
