Engine Misfires When Driving
dirtyoldman
Saugus,Ca.
The last few days the engine on my burb has been misfiring and is getting progressively worse.Before I do a tune up I thought I'd connect a vacuum gauge to see what's up.At idle the engine reads good....even while driving it reads good???:dunno:I detect no misses at idle but when driving it misses like crazy but the gauge doesn't show it....it should be jumping alll over the place,shouldn't it?When I step on the skinny pedal it takes off and goes normally,when maintaining speed and cruising it misses.
Anyone have any ideas?
I wonder if my gauge is bad and not giving me good readings :dunno:
[YT]3U4OdggQOhQ[/YT]
[YT]aM5Xovl2E9U[/YT]
Cowboy Cadillac
Ain't no trash in my trailer!
Grande Prairie, AB, Canada
By your vac reading( at idle) it should be all good. I would check cap,rotor,wires and plugs. You'll at least be able to tell which cylinder is missing if its a single slug issue or resolve the whole problem.
You could still check for vac leaks, a properly running engine should idle between 18-22 IIRC and drop 10-12 under power. I could be (completely) wrong but thats how I think it goes.
Texas Jim
Ft. Worth
If you are using platinum plugs.. that sounds like one of the platinum tips came off of a plug...
dirtyoldman
Saugus,Ca.
A basic tune up is next...I have to look at my records to see when I tuned it up last...
Pretty sure I used ACs,but I'm not sure.
It sounds like a plug issue. At night while it is running do you see any sparks jumping form the wires, which would indicate a bad wire?
Sounds like it's time for a tune up. :thumbs:
When was the last time you changed the fuel filter? :dunno:
You've already checked for vacuum leaks. :dunno:
dirtyoldman
Saugus,Ca.
At 223,500 miles I changed oil,replaced plugs,wires,cap & rotor...the burb has a little over 235,000 on it now,certainly shouldn't need a tune up already...there's gotta be something else going on..
I changed the fuel filter about three years ago,maybe at something like 205,000miles,summer of '08 IIRC.When I bought the burb mar.'08 it had 202,000 on it.So in almost four years I've put a little over 33,000 miles on it.The fuel filter shouldn't be going bad that soon should it? :dunno:
It's a cheap fix. I change my fuel filter every 15k-20k. Cheap insurance. :dunno:
I wouldn't think it would need a tune-up within 12k miles. Have you cleaned the TB?
dirtyoldman
Saugus,Ca.
A fuel filter would probably be a good idea,it can't hurt.Keep in mind I have the old TBI setup...no cleaning.I use Chevron gas so the two injectors should be pretty clean.The air filter is recent also.........
Pull the cap and have a look inside Gary. I've seen aftermarket caps get pretty corroded over a short time. What you describe sounds like a plug wire breaking down. Does it get worse on damp mornings?
