Dual shock systems
patrick141
When in doubt 4WL
henderson ky
I have a 02 f150 4x4 supercrew. And I'm getting a 4 inch lift, and i can't find a dual shock system anywhere. Its for the front. So if anybody knows were i can get one, that would help alote.
I went and had a quick look around. Everybody lists them for F250/350 trucks (and even Explorers and Rangers) but none for F150.
We need a Ford guru to chime in here.
buckshot85
Hampton S.C.
Only thing i can think of is custom fab. shop making you some. why you wanting to go with dual shocks?
bubbatrucklover
Heavy Metal Red Neck
Jacksonville,Fl U.S. of A.
It's what all the:quote: cool kids:quote: are doing.:thumbs: :crackup:
I think in most cases it's for looks. If you're not doing AGRESSIVE off roading/rock climbing (and even at that) most local 4X4 shops will tell you that with the advancements in shock technology it"s not needed to go with 2 but IDK.:dunno:
In my case I like the looks so when it was time to replace I went with REAL soft shocks since there was two.
agjake11
Oral the Coal
Rosenberg/Beaumont TX
Fabtech makes dual shock ucas that replace the stock ones but idk for sure if they fit the 4x4 and I do know they dot make them any more and you have to make or buy a dual shock hoop also to make it work. Seen it once on a 2wd with the fabtech kong travel kit and it was pretty cool but other than looks it's mostly not worth all the hassle
Just get a resivour shock (sp?)
