MagnaFlow Mufflers - MF11378
Two perforated cores in Tru-X mufflers intersect in the middle to pull gases, rather than push them, through the exhaust system. This suction effect diminishes the decibel level and boosts mid-range horsepower, improving overall engine performance.
Features:
Unique exhaust flow increases mid-range horsepower, torque and fuel efficiency, improving engine performance
Two stainless steel, perforated cores intersect in the middle of the muffler
Innovative "X"-shaped design pulls exhaust, rather than pushing it, through the muffler
Intersecting cores create a suction effect that all but eliminates noisy exhaust flow to deliver a smooth, deep tone
Lap-joint welding provides durable construction - also prevents distortion and cracking
100% Stainless steel composition resists corrosion
Satin finish
Reversible muffler functions in both directions; can be flipped around for custom installation
Welding required for installation
Made in USA
Specs:
Muffler shape: oval
Overall dimensions: 4" tall x 9" wide x 17" long
Body length: 11"
Inlet/outlet diameter: 2-1/4"
Inlet/outlet position: dual/dual
Core diameter: 2-1/2"
Lifetime warranty
The two stainless steel, perforated cores in this muffler intersect in the middle, creating a suction effect. Whereas most mufflers push gases through the exhaust system, Tru-X mufflers pull them through using suction. This type of exhaust flow increases mid-range horsepower, torque and fuel efficiency. All these factors lead to improved engine performance.
The "X"-shaped intersection that creates the suction effect also reduces loud exhaust noise. The resulting tone is a smooth, deep growl, specific to MagnaFlow.
The inlets and outlets are lap-joint welded to the muffler body for durable construction that eliminates distortion and cracking. All materials are made from 100-percent stainless steel with a satin finish, making this muffler corrosion resistant.
11378 MagnaFlow Stainless Steel Universal Muffler - Oval Shape
