Drone and a Possible Cure
BigBlueLB756
Cheap But Not Inexpensive
Mississippi
Simply put, the formula for determining the length of a Helmholtz chamber used to knock out a drone frequency is:
1100 feet/second (roughly the speed of sound) divided by the target frequency you're trying to eliminate (in cycles/second) gives a full wavelength in feet per cycle. Divide this number by 4 to get a quarter wavelength (a much more convenient length to work with). Finally, multiply this wavelength by 12 to get the chamber length in inches.
Tap this length of pipe into the exhaust tube, making sure the other end of the pipe is capped off, and you have a Helmholtz chamber that takes the annoying frequency and bounces it back into the flow 180 degrees out of phase, knocking it out. The results: no more drone.
(See the above cited forum thread).
Sodbuster
Orange is the happiest color.
Stillwater OK
Interesting solution.... I'm sure it's been done before like this, but I've never seen it....
:thumbs:
BigBlueLB756
Mississippi
The door on this exhaust technology is slowly creaking open, thanks to the introduction of AFM/DOD engines by GM and Chrysler and the accompanying "drone" when these engines shift into 4-cylinder operation. Check out Solo Performance and what they're doing with it.
DV2000NJ
The Browmaster
Central NJ
Yeah I saw that yesterday.
Just to be a bit more needy, what technique did you use to figure out the frequency of your drone? The only way I know to do it involves bringing a guitar into my truck, getting up to 70mph, and matching the drone to a note. :lolup:
azmidget91
Maricopa, AZ
for a simpler solution sound deaden your back wall, it seems the back wall on the f150's at least not sure on others resonates at about the same frequency as the exhaust
BigBlueLB756
Mississippi
Several apps are available for spectrum analyzers on cell phones that work well and are covered in the G8 Board forum thread cited above. The drone I was after was approx. 115 hZ, which worked out to be 27.5 inches, or so. Someone will use this theory to deal with unpleasant aftermarket truck exhausts. I just threw the idea out there to get the party started.
A solution is always better than a band-aid.
