daddy's new Tahoe
Anyone know where the reverse light lead is on my Tahoe? BCM? Any idea which wire?
My backup cam will be here on Monday and I'll need to tap into that wire to tell the head unit to display the image. The cam itself is powered by the reverse lights but I don't want to have to run a lead all the way to the front for the actual trigger on the HU.
dietz4ibanez
Willow Spring, NC
Do you think that you could start at the tail light and remove some of the side paneling in the cargo area of the hoe to follow the reverse wire into the main harness...
If worse comes to worse you could do a wire poke with a continuity checker...
I could give you the bill190 canned answer from GMT.
What you need to do is purchase yourself a set of books and stop asking questions.:D
And here's my canned response.
Have you used your bluetooth yet?
Yes. Only once though. So far it's okay. It has an external mic setup so it's pretty clear. I'll need to use it more to be certain.
