bubbatrucklover
Heavy Metal Red Neck
I know that Jarrod and Dan are both running long tube headers and they both have 4wd trucks.![]()
I'm just wondering if for some reason it doesn't show "factory fit" for 4X4's as a disclaimer of sorts because it would move the position of the cats back.where as for 2wds it wouldn't.
I didn't want to order them at $500(ish) and find out there was a routing issue.
Ok... Think about it this way.. You have two rivers flowing and you confine them down to one.. and then split it back to two (if you do a Y and then another Y..) You'll have a bottle-neck of flow where you confine it down to one and then split it back out. I wouldn't do that...
If you're going to do duals, do true duals.. all the way back.. Yeah, a cross-over pipe will help balance pressures. So, you'll want that.
But a Y and then another Y..... No, I wouldn't do that..
Didn't make sense to me either I was just looking at the crossover pipe and trying to figure out it's application.
I might not be the BIGGEST idiot at times,but I can be an idiot.
