B
Bernie
blown the output final of the cb? huh?!
and i need to have a ground on the antenna?
The output final on the CB is a power transistor that amplifies the signal before it gets transmitted. It usually burns out if you have a very high SWR (Standing Wave Ratio - reflected power) in the antenna system. With it blown you'll still transmit, but with very, very limited range. Normal CB output is 4 watts, but with a blown final your output would be around a half watt.
Most CB antenna systems rely on the antenna mount providing a good ground (except for magnetic mounts) to the body of the vehicle. Not having that ground, or having a poor ground, will result in high impedance in the feed to/from the antenna, which will cause a high SWR. A short in the antenna, in the mount, or in the cable will also cause some serious problems.
The fact that your system seems to have blown your stereo amp because the coax was close, despite the coax being good quality with good shielding, indicates to me that you either have an amp with little or no RF shielding, or that the reflected signal in your antenna system was so high that even with the good coax you radiated enough power to overload the amp.
Now, another possibility, that your friend at the audio shop seems to be discounting, is that you fed too high of an input from the CB to the amp. That would be pretty easy to do, since the "Ext. Speaker" jack on CB's provides a pretty high output (5-10 watts), and your amp may not have been able to handle that as a direct input.
