CB install with pics
Mcdiver
I'm crazy, but it's paid for!!
Raleigh, NC
Not to be mean here, but with cell phones, does anyone even use CB's anymore? Sorry to hear about your amps, you could shield the antenna wire, that would eliminate this problem in the future.
che22879
< Yes that was my foot!!!!
Los Angeles
No signal up in the trails and to be safe communication is key.
OG-Unleashed
WHAT A LIFE RIGHT.....
SoCal
im thinking about using black tape around the atenna wire or something to close off the signal so it can he just on the wire until it gets to the antenna
OG-Unleashed
SoCal
Truckspec TS-18CC 18' CB Antenna Coax Cable with PL-259 Connectors - Black (1 Each)
B
Bernie
Probably RG-58/U, which has pretty good shielding. If it killed the amp just by being within a few inches then your SWR is probably through the roof. Probably around 5:1. You may have blown the output final on the CB as well.
Likely the problem is either a poor ground on the antenna (or mount), or a dead short in the antenna, mount or feedline.
OG-Unleashed
SoCal
blown the output final of the cb? huh?!
and i need to have a ground on the antenna?
