Built Ford Fast???
Stumpuller6.5
Shits gonna get Abrasive...
Canukian Land
Yeah how the **** is only installed a high pressure fuel pump, new fuel injectors, new turbos, and modified the compression ratio. production class!?? :crackup:
dietz4ibanez
Willow Spring, NC
What they don't know is that the new Fords can run heavy tunes without said modifications...
- The brace kits/sleeves that you have to add on most trucks to do 4wd launches you don't need to on the new Fords
- Fuel system can easily handle larger amounts if hp with out needing a more performance fuel pump and injectors.
- The motor can handle high hp numbers without doing.
' Yes their truck was modded- Not Stock. Not that I want to defend a ford its just what is found in the Diesel modding world right now..
Would I ever buy one? NO :D2
