Amsoil ATF tranny flush on the Xterra
Wyley87
Granbury, Tx
Well if your fluid meets spec you shouldn't have a problem.
David, as long at the transmission was well serviced and the fluid is still pink and not brown there shouldn't be any issues. I have changed out a few over 100k miles on the transmissions with with the fluid being as stated above and they continued on with no issues.
The only time it will cause issues is when your transmission is worn to crap, and ran forever on burnt fluid... It's not so much the synthetic fluid that causes the issue... It's all the bits and pieces of transmission that are floating around helping it still work that get flushed out that causes the problem...
I have never serviced my wifes transmission and it just broke 100k miles. But the fluid is still bright pink and doesn't smell burnt at all. Is the ATF a suitable replacement for the Nissan K-Matic fluid? :dunno:
Scotty, the AMSOIL ATF is what your Nissan takes as well. :)
You're good :thumbs:
APPLICATIONS
AMSOIL Synthetic Multi-Vehicle ATF is recommended for transmissions, hydraulics, power steering and other applications requiring any of the following specifications:
• GM DEXRON® III-H
• Ford MERCON® & MERCON V
• Chrysler ATF+4®
• Toyota Type T-III and T-IV
• Honda Z-1 (Not CVT)
• Diamond SP II & III (Mitsubishi/Hyundai/Kia)
• Mazda ATF-III, ATF-MV
• Subaru ATF, ATF-HP
• Nissan Matic D, J & K
• Idemitsu K-17
• BMW LA2634
• LT 71141
• Audi G-052-025-A2 & G-052-162-A1
• Volvo 97340
• MB 236.1, 236.2, 236.5, 236.6, 236.7, 236.9 & 236.10
• JWS 3309
• NAG 1
• ETL-7045E, ETL-8072B & N402
• Voith 55.6335.XX (G607, G1363)
• ZF TE-ML 03D, 04D, 09, 14A, 14B, 14C, 16L, 17C
• Allison C-4, TES 389
• Mopar AS68RC
Note: Not for use with CVT or Ford Type F applications.
davbell22602
Stihl Chainsaw Man
Bunker Hill, WV
My fluid is pink/red color. What will synthetic do to the one check ball that sticks at times? I have 130K
Wyley87
Granbury, Tx
Note to self. "when flushing your tranny order more than you need. ". On my way to oriellys.
Sent from my iPhone 4s
Wyley87
Granbury, Tx
Well I got it all done finally late last night. I have all the pics on my job camera I'll upload and post em up this PM. I got every thing except the flush set up and flush itself. Now I got to do this to the '96 as well as replace both oil cooler lines.
Also I wanted to add that if you are doing this for the first time, don't use a big jug of tranny fluid as I did. It made keeping track of how much I was putting in difficult.
