9 Inch is broken!
dietz4ibanez
Willow Spring, NC
I was about to say. Appropriate it is but dang... That's kinda something to brag about!
Yeah, I laughed when I pulled the axle shaft out.. i was like ok, I see you big dawg, tearing it up!! lol.
I was trying to think what GM make that you could use but you can't... 10 Bolt was in it from the factory, right?
Yeah that would be a joke... And a 12 is like a slightly modded 10 if you could...
And then once you are at a 14 bolt talk about packing on the pounds! :lol:
That's the thing about upgrades, they will always find you weakest parts for you. I found out today that I will need to upgrade injectors if I lay down anymore power. Knock on wood, the transmission is still hanging in there.....
Yeah! More spray for all that new air!! lol...
I would hurry up and give FLT a call on the trans, ive seen a couple 4l60e's let go! lol.
He added a little torque management for me so I would be safe for a while. Hit 11.3 psi of boost and the injectors were at 98% duty cycle.:thumbs:
Alljackedup408
Shut Up Stupid
Titusville FL
Yeah, I need either a serious dana 60, or a Fabricated 9 inch, I need to keep it somewhat light. LOL
Alljackedup408
Shut Up Stupid
Titusville FL
Dang man! What were you doing?
Well... I was actually just cruising, pulled out onto an empty street, and did a pull, around 6000rpm or so I felt the truck kick out from under me, let out, looked in the mirror and saw 2 fat black stripes... then it turned to only one. lol.
No wheel hop or anything cause I laid into it, not just smash. Idk lol. Im good at trashing stuff.
Alljackedup408
Shut Up Stupid
Titusville FL
sweeeeeeeet!! :thumbs: mo boost. now!
66nova
Fort Worth, TX
Im looking on my phone so I can't see the pics too well. Besides axles and caps what is broken?
Looks like to me a set od billet caps, bearings and a good set of axles and you should be rolling again.
Alljackedup408
Shut Up Stupid
Titusville FL
Yeah, Im thinking about maybe changing the whole rearend housing out, make it a bit wider, if not I will be going to 33 spline, billets and new bearings. If i can find a deal on a moser center section, ill do that! craigslist for the win!
