'63 Chevy step side
63chevystepside
High speed low drag.
us
Im putting in the drive shaft on the 63 today-do i put grease inside the yoke that goes in the tranny and or around the yoke that goes in the tranny so it don't rub the rear tranny seal?
Just grease inside the yoke. A light coat on the outside won't hurt it, but the inside is where the slip takes place.
hotrodpc
Some grease inside the yoke is fine if you want to. I wouldn't put it on the outside at all, it'll just spin off and make a mess. You can put a little trans fluid in it or on it too. It'll get some trans fluid from the trans when you start driving it. Not a big issue really. Put it in and drive it.
63chevystepside
us
Ok cool thanks hot rod-im not far off from testing that tranny. O its bout time you showed up around here-missed ya!!!Im glad iv already got it on and just put a little tranny7 fluid in the yoke and didnt wanna yank it back off but i would of...What you think bout a 72-or 75 mg midget? Think a 350/350 can fit in it?Curb weight on it is like 1620lbs.
63chevystepside
us
Im changine the rear diff. fluid in the 63-Its brown!!! I wanted to clean out all the old fluid would using carb. cleaner be safe to spray in there to get all that old diff. fluid out?
That or brakeclean will be just fine.
hotrodpc
Wassup??? Have you not taken this thing out for a test run yet??? What's the hold up???
hotrodpc
Earth to Joe, Come in Joe !!! Wassup with the 63??? I'm curious about the transmission and how it works??? Need any adjustments??? Shifting late or early???
