Yes you would.
You need air, fuel, and fire(and timing).
You need to make sure the fuel pump runs, it should prime and turn off on the on position. Then you need to know if you are getting the correct PSI at the rail. I assume it going to be 50-55psi. With a 2-5 psi drop and hold with everything off. Once that is verified. Then you need to check spark. If you have to, pull a plug and either put a spark tester on it or ground it out, turn the engine over and see if that is happening. I'm not sure of the values, but you can chech the ohms of the wires.
