1971 C-10 "ResuWrecktion"
slims
gonzales LA.
That's awesome work!
Nick The Great
How are you gonna title this thing? There's very little that is a "1971 C-10" truck anymore.
Kinda like George Washington's ax, where the handle had been replaced three times, and the head twice. :lol:
All meant as a compliment, here. A lot of work and looks very well done. :cheers:
No offense taken. In reality the cab is still the same, just patch panels to replace the rotted areas, the VIN plate is attached to the B Pillar about a foot up from the rocker panel. That matches the title..
Now, the frame. Yes I am changing everything on the frame EXCEPT the frame rails. They have a VIN on them that coincides with the title also. Outside of that nothing else matters as far as the title and registration is concerned.
From a "purist" standpoint it isn't gonna be numbers matching though. I let the original block get away from me when I sold my shop but the transmission and rear end are all original. Well the housings at least. :lol:
The original block was in the process of becoming a 383 stroker. I gave away the long block and a set of Dart II heads when I sold my place. God only knows where it is now and it's not a big enough concern for me to chase it down. Titling and registration won't be an issue and I'm good with the history of the truck and comfortable with it's future.
I know you should never say never but... I never plan to sell this thing.
Oh I was just joking about the titling thing. So much work going into this thing. I can't imagine getting rid of it any time soon either :cheers:
Weekend update!
Got a little more done this weekend, sometimes I feel like I have ADD.
There are so many things to do to the cab that I bounce around like crazy! Oh well it all has to get done one way or another!
I took out my cross braces that I had installed prior to cutting the rocker, floor sections and cab supports out. That led me to the High hump install and trimming out the floor for that. I decided to weld it in, I know "what if you need to get to the transmission?". My reply would be that for a truck that's 44 years old there has never been a removable hump there.
So with my hole trimmed and a few tweaks with a hammer and dolly I got it fit well enough and welded it up. Still have a couple of bolt holes to fill but it's getting there.
I think I've had that oil can with Cleco's for a while. Been a long time since I've seen Gulf Oil or a round plastic can.
Started cleaning the rust out of the windshield seam and coming up with a plan for fixing it.
Decided I didn't want the rear cargo lamp anymore, so I plugged that hole with a patch from behind. Not perfect but a little mud will make it invisible.
All of the old paint is removed from the back now but this was the last pic I took after grinding down the weld.
Labor intensified love going into this project. How does the wife feel about this affair you're having? :lol:
