Nice write up Nick. How in the hell did you get the drain plug out? I did this to my '99, but the drain plug wouldn't budge.
Nice write up Nick. How in the hell did you get the drain plug out? I did this to my '99, but the drain plug wouldn't budge.![]()
I had removed a long time ago and had to use the Craftsman bolt extractor set to get it out. Mine rounded off and the bolt extractor worked great at removing the now bad drain plug.
That's a bit of an understatement. Mine looked like something had been chewing on it. I should probably do this to my new one. It needs to get a hell of a lot warmer for me to even think about crawling under there.![]()
You may have said this already but how often do you suggest changing it?
Nice...
old Fluid was super clean...
Now do a write up on installing those ceiling fans.![]()
did you use any RTV sealant or anything on the gasket, or just lay the gasket on the top edge of the pan and then just bolt it up?![]()
