Sub/amp/box help needed
Z71 Kris
Independence...
N. East Ohio
cool, I'm glad you like it Jon..
Matt audio wiring is not hard, just make sure you have a good ground and follow the wiring instructions..really simple, but if it really scares you then check out places like Bestbuy, HHgregg, and maybe buy an amp form them and have them install it for you, usually they wont install something they havent sold...the other thing to do is check some buddies and see if they can do it, I am one that a lot of friends come to looking for a little help....then when things get outta hand for me I have friend to go to for help as well...
buckshot85
Hampton S.C.
Hey Jon one quick question does it matter about the 2 ohm or 4ohm?? idk which the speaker is because that Infinity differs based on that
Boilerup15
Hate Milk! Got Beer?
Markle, Indiana
The sub is a 4ohm. It does matter, just depends how you wire it all up. Crutchfield has good diagrams on wiring.
Boilerup15
Markle, Indiana
Just wire it like this you will be fine, you will be pushing 400rms to the sub I believe.
bigredstx
If they don't scrub, they're not big enough
I love working with audio stuff
buckshot85
Hampton S.C.
So the Infinity amp is good. 4 gauge wires good or should i go a little bigger? i'm sure i can find a wiring kit instead of buying it all out seperate. and one more thing will it be to much power for my stock unit? i have a friend good with speakers so he's going to help me run everything i just want to make sure i have the proper items so nothing over heats
bigredstx
Im not to sure about the wire sizes but hiding the wires are easy just pull up the door sill things or whatever theyre called and there's alot of room in there to put the wires. just remember to run the power wires down one side and the RCA ones down the other side
buckshot85
Hampton S.C.
does it matter which one i run down which. lol. and as far as RCA do i need to take my back door panels off to connect into the rear speakers
