Steering Gearbox
I`ve rarely ever replaced steering boxes, they are very stout peices, I don`t see a point in replacing it unless you have over 300k miles, they are adjustable for internal wear. Unless the box is binding after several adjustments, there should not be a need to replace it. :dunno:
And typically the 3/4 ton boxes use different pitman arms, with a different number of alignment splines, and then who knows if the 3/4 ton pitman arm is longer/shorter/different angle/different size....etc. :)
People would take the ZQ8 steering box and put it in the S-Series...
Quicker ratio for more responsive steering :thumbs:
Still, if the steering box hasn't had any problems, don't mess with it... Power steering pump, however, could probably use an upgrade for the bigger tires :lol:
Thanks to both of you.:cheers: This all started months ago with wanting an alignment. I was given a list of 6 things needed(pitman arm,idler arm,idler arm bracket, DS ball joint,PS hub assembly and new bushungs for my lift) did the hub assembly and ball joint ASAP.
I wasn't sure about the stoutness of the steering box. I have the choice of $200 labor to pull the current steering box and remount it along with the new pitman arm(which I have) and then align. Costing me $200(OBVIOUSLY:uhoh:) plus alignment OR replace both parts new for about $400 ish.(plus alignment) My only concern was spending another $400 parts and labor down the road "IF" the gear box fwonked up.
So far ya'll and several others have assured me that I would be spending too much at this time for a "what if". Thanks again. I will precide with the old box and new arm.:thumbs:
That's $200 you can put in the future mods fund, just in case :thumbs:
