Rear suspension
5.3silverado
On a 2004 Silverado 1500 rear end is the enough room for a 1" spacer between springs and rear end? Is there enough thread on u bolts to do this?
Sent from my XT901 using Tapatalk 2
NGM7492
Changed
Tallahassee Fl
I do not like to re-use U bolts. They are cheap. Get whatever size U-bolt you need and put new ones in with your spacers.
I don't think the OEM bolts would be long enough. At least a new set isn't very expensive.
People often say they would not reuse U-bolts, but I've seen it done a zillion times at our body and custom shops over the course of about 30 years and never seen one fail.
I have some stock lift blocks from my GMT900 you can have... Just pay shipping
If you don't have some already :lol:
They should fit :dunno:
BlueCollarPilot
Boy I say boy
Louisiana
I apologise if I am misinterpreting your intent. If I understand correctly, you are wanting to "stack" a one inch block with your stock block. If I remember correctly, yours ('04)should be a two inch? Personally I would buy a solid block that will give you the height you want. I know, "people stack blocks all the time and never have any problem". It just makes me nervous. None of my business really though. Some quick measuring should answer you question, but I do believe you will need longer u-bolts.
2004 Chevy Silverado 1500HD Readylift Rear Block Kits, Ready Lift Suspension Block Kits
Gotta get 'em good and broken in! :thumbs:
NGM7492
Changed
Tallahassee Fl
Well I am not sure what you mean by custom, do you mean pavement queen custom or hard mudder custom? I did not do much pavement queen custom, but ALOT of offroad custom stuff. I have seen U bolt that were re-used fail. Also the threads get stretched and then its a PITA to get them off later etc etc.
