Raw SS, Steel, & Aluminum
AllBlkdOut07
UMBERTO de magnifico
Rockaway NJ
Nice, those look purdy. Tubular ones are stronger, but I like the beefy look of the boxed ones. :naughty:
Looks like some good stuff!! :thumbs: So will these UCA's use the same balljoint as the factory one? (that would make part searching A LOT easier)
What is the Mag-Hytec cover for? 10-bolt? 14-bolt SF?
They use a ball joint similar to OEM that bolts in, pretty sure they are readily available.
MH is a 10 bolt.
I meant if they used the same balljoint part number as the factory one. That would make it so that you didn't have to remember a special number for them.
Darn, was hoping it was a 14 SF. :(
Those look like they should go on the Saturn. Weak. :jester:
