I've always heard good thing about Troyer Performance
http://www.troyerperformance.com/cgi-bin/ppistore.pl
no problem greg
dude I can't wait to run the 1/4 mile with this thing, Hondas beware! too bad matt traded in his denali, I wanted to see what the 6.2 had in it...
If it all holds together and you have traction, I can see that thing being well into the 12s. We're probably going to be running similar power levels, and I've got almost an extra 1000 lbs on you.
I doubt your ranger is that heavy.If it all holds together and you have traction, I can see that thing being well into the 12s. We're probably going to be running similar power levels, and I've got almost an extra 1000 lbs on you.
What does yours weigh Dan? I'm not sure what mine is, I do know that a single cab short bed 2wd with a v8 weighs about 3700, so add my larger cab, bigger tires, and an extra axle, driveshaft and transfer case and I'm guessing I'm around 4200-4500
