B
Bernie
Be aware though that the Quad Beam mod is for off-road use only, and is illegal under FMVSS-108 for use on the highway.
I thought that it is illegal if you have more than four headlights working at once. After all, the GMT900 trucks have the quad-beam setup from the factory.Be aware though that the Quad Beam mod is for off-road use only, and is illegal under FMVSS-108 for use on the highway.
Its not like he will be driving around with them on in traffic. I wouldn't worry about the legal aspect at all. If they only come on when you would be using your brights then I don't see a problem.
Like I said, his chances of actually being stopped for them are pretty slim. But, if he lives in a place with annual safety inspections (like NY or VA), he could end up failing the inspection.
As with anything else in life, it's always best to know the rules before you do something, so you can make an informed choice about what you plan to do.
He could always wire an interrupt switch into the relay trigger wire
Almost everyone with non-factory HID's is breaking your DOT laws
Canada's laws are pretty lax on that... We have a maximum lumen output, and our light bulbs must be clear, and we can only have a maximum of 4 lights on at a time.
