Also, in case you haven't found it yet the parking lights will be a dark brown wire on that truck.
OK so I guess I'll need to use a relay then.On another side note:
Do I need to make a harness like this? - Look at the diagram below the image.
I don't really understand the point of this though. Some guys have said that the newer GMT400's need a relay harness whereas the older ones don't. I'm not sure what happens so you know you need one, but I'm sure I'll find out when I try to use them without a relay harness.
Is the question "Do I need this for my HIDs" or is it "Do I need it for the LEDs?"
For HIDs, yes, for LEDs, no.
GM trucks, up until '01 or '02 (maybe even beyond) used undersized wire for the headlamp feeds, which means the bulbs get less voltage than they actually should. To correct this a few places sell (or you can make it yourself) a wiring harness that uses a relay to control the headlamps, and feeds them directly from the battery with proper sized wiring. It plugs right into the existing harness and uses the power that would normally be illuminating the headlamps to just energize the relays (one for each bulb), which then feeds them power direct from the battery. HIDs can be very sensitive to voltages, and if the voltage is too low may not even illuminate.
Can I buy a factory end that is on the wiring harness of the vehicle (male end; 2 prong) at my local parts store so I can still make my harness plug-and-play?
Thanks Scotty. I'll look for that on the back side of the headlight knob. (haven't started yet; hopefully Sat if not Sun)Also, in case you haven't found it yet the parking lights will be a dark brown wire on that truck.![]()
I'll start checking AutoZone, Advance Auto, and O'Reilly web sites tonight. If I can't find them there, we have a CarQuest, NAPA, and another large, local shop that has more stuff than I can imagine (United Auto Supply if anyone cares).Most good parts places will have those, or be able to order them.
EDIT:
Found some, but they are only the connector; not pigtail. But I'm guessing it is pretty easy to put the wires in the connectors and crimp them in. $2.79ea at Advance Auto (AutoZone & O'Reilly $5 or more).
So I'm guessing that now I'm gonna need 3 relays to make the lights work.
1 - relay from stock low beam wiring to relay that gets power from battery/fuse box
2 - relay from stock high beam wiring to relay that gets power from battery/fuse box
3 - relay getting signal from high and sending power to low; getting power from battery/fuse box
OR can I eliminate a relay and send the signal from the stock low beam wiring AND the new high beam wiring power ALL (both signals) to the relay for the new setup for the low beams
Does this make any sense at all?
If not, please re-write to clarify.
Will 14ga wire be enough for all this wiring? A chart I found (HERE) says that 14ga can handle 40amps. And using their equation, Amps X Volts = Watts, it can support 480watts??? Seems high.
My relays are 40a (support 4x 55w driving lights or 2x 150w off-road lights), but I will be using a 20a fuse or whatever the HIDs draw (I won't go bigger than 30a, but nothing needs anything that big anyways).Your relays are probably rated at 30 amps, so 14 ga. will be fine. I wouldn't try to eliminate one of the relays in the headlamp setup unless I knew exactly what the current draw was going to be. Too easy to exceed the capacity of the relay, or push it to the limits. Also, check your HID package and see what it comes with. They may have included a harness as part of the installation kit. In fact, I'd be surprised if they didn't.
Hey Bernie, here are what the ballasts say:
35w
V in = 9-16 V DC
V norm = 13.2 V DC
I norm = 3.2 A
I in max = 5.5 A
Pout = 35 W norm
T case = -40 deg C ~ 105 deg C
V start 23 KV max
55w
They don't have stickers on them !!!!!!!
FYI, HID's can spike over 25 - 30 amps during ignition... probably more, because my DMM is slow![]()
