B
batman
fixed!!!!, I would not have to balls to do it.....
a 2 peice wont fit in my truck..its a solid driveshaft.....
i wouldnt do that though...too much work and it would just add another joint and another place for it to fail..as it stands now it can only fail in 1 of 2 places....
i was reffering to the shaft itself..but yea..that too...way too many places to fail as it is!i wouldnt do that though...too much work and it would just add another joint and another place for it to fail..as it stands now it can only fail in 1 of 2 places....
3 places... U-joint. Slip yoke (or however your transmission outputs to the driveshaft). Driveshaft.
3 places... U-joint. Slip yoke (or however your transmission outputs to the driveshaft). Driveshaft.![]()
i know what it is...its the yokes in the shaft and the rearend...if it will last till january i already got a guy who will makem at yeary's drivelines in middlsboro ky...i was reffering to the shaft itself..but yea..that too...way too many places to fail as it is!i wouldnt do that though...too much work and it would just add another joint and another place for it to fail..as it stands now it can only fail in 1 of 2 places....
Find out what's tweaked on your truck and fix it, or you'll keep blowing u-joints
