My 2nd Detail
Dukers
I Need to Choose a Second Topping!!!
Phoenix, AZ
i start on monday... ps havent read the sticky yet but im excited.. think ill wash the truck tomorrow.
mblouir
I need a hobby.
Greenville, SC
Man with the stuff you put yours through it would probably take me a week at the pace I go. :lol:
Dixie Fix
THATS HOW WE DO IT IN DIXIE
Tampa, FL
blaahaha,
the truck has no tires or suspension. just the frame and body sitting about shoulder level. i just need to get the underside all cleaned up.
any recommendations?
mblouir
I need a hobby.
Greenville, SC
Are you talking about getting rid of rust or just dirt/mud?
If just dirt/mud I'd say buy a gallon of Meguiar's APC+, dilute it 2:1, and go to freaking town. Spray everything down several times. Just soak the crap out of it all. Then take a hose/pressure washer and spray it all off. It's some powerful stuff. If it's not strong enough take a stiff-bristle brush and scrub it while it soaks.
Dixie Fix
Tampa, FL
ok ill have to check that out.
theres not much rust, all the caked up mud provides alot of protection against rust. :lol:
Mud, dirt, power streering fluid, oil, diff fluid, brake fluid, some blood. thats mostly the gist of it.
mblouir
I need a hobby.
Greenville, SC
APC+ is your best friend, then.
http://www.amazon.com/Meguiars-Purpose-Cleaner-Plus-gal/dp/B002J7VNIK
It's expensive but it's in a gallon and can dilute to many different ratios. I use 10:1 on interior stuff and 5:1 on most exterior stuff (tires, exhaust tips, etc).
For heavy duty stuff you can try 2:1 or 3:1. So essentially if you use all of that for your underbody you have 2-3 gallons of the stuff. I doubt you'll use all of it, though, so you will have some leftover.
Dixie Fix
Tampa, FL
ok Ill definitely give that a try after i get the motor, transmisson and t-case pulled
