NMRam
With the TTB front suspension on that, if you already have coil spacers and drop brackets, I don't know that there is much else you can do without springing for a full-blown lift. If you go much higher without dropping the axle, your tires will be bowed out at the tops and you would never be able to align it.
A body lift might be your only choice without spending quite a bit of money.
