vansdonk
That's not buffing out
OK, so I'll just watch and learn.
Whether you crank the t-bars 2" with the stock keys or aftermarket keys, the amount of wear will be exactly the same.
x2
If your "certified gm mechanic" buddy is telling you that if you get leveling keys then there wont be any wear & tear as opposed to cranking the stock keys, then he's the worst mechanic i've ever heard of and doesn't know how the suspension works
For your truck, keys are worthless. You should be able to crank the stock keys until the control arms bottom out on the droop stops.
For GMT800+ trucks, the only reason for "leveling keys" is to get more than the .75-1" that the stock keys allow.
EDIT: damn... either you all are typing really fast or this Advil-PM + Yuengling combo is starting to kick in.....
when i had my stock ones maxed out it didnt come no where near the drop-stops
I was talking about the OP's truck which is a 1998 GM, not a Ford. In 1999 even GM changed their key indexing so that maxing out the stock keys won't get you up to the droop stops.
But as far as the 88-98 GM trucks are concerned, if the stock keys don't get you touching the droop stops, it means the torsion bars are worn out![]()
Me too, lowering keys here.I have the keys.
I did it because Matt told me not to.
I have the keys.
