lukasmcdukas
why is the road i travel paved with good intention
hey yall, looking for a little knowledge on the 4WD side of the house.
i tore into my 97 nissan d21 this morning with the plan of changing out the rusty brake rotors, calipers, and pads for all new parts. cake, right? not when im on the job!
the wheel hub needs to come off to get at the rotor... no big deal... however, two of the bolts that hold the wheel hub to the rotor won't back out all the way. they're loose and spinning, but too rusted to come all the way out. so, im looking at replacing the hubs and hardware too.
here's my question: what the hell do i need to grease these things properly when i install them? i'm a nuts and bolts kinda guy, never had to pack grease. this truck has manual locking hubs that need to come apart and then all the collars, snap rings, and i think even the bearings need to come out to get the rotor off
the haynes manual leaves too much to the imagination for my liking
, and my mechanic buddy's best input was: "usually they just leave the rotors on and turn them down while they're on the truck" super friggin helpful
so i'd like to get as much input as possible.
lastly: the driver side rotor is completely warped (stuck piston) and the truck has a nasty wobble at 45... i THINK the wobble is from the rotor, but could it be the wheel bearings? should i swap the wheel bearings while i'm in there?
im a total NUB in this area of expertise.
thanks!
. the haynes manual leaves too much to the imagination for my liking
so i'd like to get as much input as possible. lastly: the driver side rotor is completely warped (stuck piston) and the truck has a nasty wobble at 45... i THINK the wobble is from the rotor, but could it be the wheel bearings? should i swap the wheel bearings while i'm in there?
