Idle issue
Depending on cost, you might as well replace everything while you're in there...
See if you can track down a Hurst or B&M Short throw shifter... Best thing you could ever do for the NV3500! The shifter doesn't bother me that much. Makes a nice place to rest your hand too when you're messing with the radio/HVAC. Try putting a tall cup in the bottom cup holder in 4th gear... And the short shifter still leaves a resting place for radio stuff.
If I would've had a few days, I'd have pulled mine... I know I could've made money on it, since they stopped making them before I got mine...
Nice parts list. :rolleyes: :lol:
I'm searching, and guys are talking about replacing seals (some mentioned are the engine rear-main seal, and trans/t-case seals). Should I even try messing with the engine rear-main seal? I really don't want to fWONk something up.
If you have it out, you might as well do preventative maintenance...
I never got around to doing mine...
See if you can track down a Hurst or B&M Short throw shifter... Best thing you could ever do for the NV3500! The shifter doesn't bother me that much. Makes a nice place to rest your hand too when you're messing with the radio/HVAC. Try putting a tall cup in the bottom cup holder in 4th gear... And the short shifter still leaves a resting place for radio stuff. Umm...tall objects don't work in either cup holder very well. Never thought about that. Still can't find one though. Is anyone still making one?
Yeah, I'm going to try to replace everything I can while the trans is out (really don't want to take it out again until I have to rebuild the engine or another 100k mi), but should I mess with the engine seals at this time?
On the idle issue, the truck seems to be doing better, but still occasionally will hold a high RPM. I'm just hoping that the ECM/PCM is learning the right way again.
