How to clean a Mass Air Flow sensor (MAF Sensor)
I decided to clean my MAF sensor. Here is the basic rundown on how to do this quick and simple task on your own truck. It took me about fifteen mintes total. My truck is a 2001 Suburban, but most trucks should be similar. The cleaning process is the same.
First, get a can of CRC Mass Air Flow sensor cleaner from your local parts store, or wherever else you can find it. I found some at my local O'Reillys auto parts store for about 7 bucks a can. Pep Boys also has it. Advance and Autozone do not carry it. I didn't check anywhere else. :dunno:
Now you need to remove your MAF sensor from the truck. It will be mounted in the air intake tube next to or near your air filter box.
It will most likely be held on with some type of clamps. Mine has two stainless worm gear screw clamps. Just undo the clamps, unplug the wiring harness, and you should then be able to remove it.
Here is how dirty mine was.
Now simply just spray the sensor off with the cleaner. Be careful to not touch any of the metal bands or wires that span across the inside. I cleaned off the mesh with a back and forth sweeping motion. Here, this pic shows it halfway cleaned.
Once you get it all sprayed off and clean, let it dry off. Do NOT put it back on the truck till it is dry. Here is mine all cleaned up now.
Looks good as new! :thumbs:
No just go install it back in your truck. Installation is reverse of the removal process. Just make sure you do NOT forget to plug the wiring harness back onto it. Get your clamps all tightened up and you are done! :thumbs:
700 sportsman
NW, Ohio
Hmm, I may have to do this sometime, but I doubt it's worth it with only 56k
I have started doing it when I clean my air filter. With all the work I've been doing lately to the truck it's been done 3 times in the past 6 months. Overkill maybe but it's clean.:D
